Shifter got stuck in park twice tonight
Old Oct 31, 2013 | 11:48 PM
KlamathMatt's Avatar
Default Shifter got stuck in park twice tonight
Drove the disco several times tonight (kids trick or treating). On 2 of these occasions the shifter wouldnt move out of park. I got it to budge when i used my body weight to rock the vehicle...this seemed to release the shifter on both occasions. the other 4 or so times i was in and out of the truck tonight it shifted freely. It hasnt yet stuck again but i was wondering if this sounds like a problem you are familiar with. On one occasion tonight, i noticed an audible "clunking" sound when i went to move the shifter from P to R. This was on a steep incline? But that too hasnt been replicated on any other occasion tonight.
Also is there a law or principle in rovernomics that says when you fix one problem, another one manifests itself within days? This seems to happen to me all the time of late...thanks for any light you can shed on this....much appreciated.
Old Nov 1, 2013 | 01:13 AM
dr. mordo's Avatar
When you press the brake pedal, do you hear the solenoid in the center console click?
If not, that's yer problem.
Old Nov 1, 2013 | 02:48 AM
bballjames's Avatar
Originally Posted by dr. mordo
When you press the brake pedal, do you hear the solenoid in the center console click? If not, that's yer problem.
X2
If it ever gets stuck and it doesn't work after a minute, just pop the shifter cover off and you can manually push the solenoid in and shift. Might want to check the leads to the solenoid, they can loosen up and cause this issue.
Old Nov 1, 2013 | 11:03 AM
thanks for the info...I dont hear a click, but i am not sure i ever have in the 11 months i've had the vehicle. Is it a faint sound and do you need to pop the cover off to hear the sound? I havent had any shifter-getting-stuck issues resurface. I am going to install an 04 CDL next weekend, is there anything worth doing then? should i replace or check anything?
Old Nov 1, 2013 | 11:06 AM
dusty1's Avatar
with radio off and windows up, you should have no problem hearing the click. easy to just follow brake pedal arm to see that button operating.
Old Nov 1, 2013 | 12:47 PM
bballjames's Avatar
Just check the leads to the solenoid to make sure it is attached securely and that there is good contact being made. And like Dusty said, you definitely should be able to hear the click when you push the brake pedal down if there is no other ambient noise.
Old Nov 1, 2013 | 01:29 PM
earlyrover's Avatar
"Also is there a law or principle in rovernomics that says when you fix one problem, another one manifests itself within days? This seems to happen to me all the time of late...thanks for any light you can shed on this....much appreciated."
YES, but it is not called rovernomics, it is called Merphy's law, and usually happens at the worst possible time, at the worst possible location. Auto. Insurance companies don't like it at all, when a guy tells them something like "yes, I was hit from the front, but it now has caused my rear differential to be damaged!"
Seriously, though, do as the guys here are trying to tell you. It sound as if you have a non functioning solenoid, so inspect it carefully--you may have to put in a new one.
Old Nov 1, 2013 | 05:28 PM
dr. mordo's Avatar
When I did my CDL shifter, I completely removed that solenoid to avoid the exact problem you are having.
You may want to consider the same.
Old Nov 1, 2013 | 07:52 PM
flemmons's Avatar
I have a similar issue getting stuck in park and every time my F21 fuse in the fuse bank under the steering column is blown. I replace it and all is fine. I think it may be my solenoid. Fuse 21 covers Shift/i lock/Alarm/Transfer Box. I am stumped and know if I keep replacing fuses, I will burn up my fuse box.
Old Nov 1, 2013 | 08:42 PM
Thanks for all the input...looks like i got some things to check out...i will be looking at rave tonight....what is the purpose of the solenoid? It sounds like you can remove it as opposed to replacing it?
I had a busy day of running around without the selector getting stuck but when i got home my wife told me i have no brake lights -- it sounds like this is all related.....
