Shock/Spring Replacement Question
good afternoon.
i have a 2001 disco with 150K miles on it.
when i bought it the rear left bag was leaking and i was scared of chasing the issue so i did the strutmaster conversion on rear.
the 4 shocks and the 2 front springs look like original.
can someone advise on the following:
do i need any 'special' specs on front spring to make sure they match the strutmaster rear? what are the recommended shocks (light, med, heavy) if 95% of use is on-road (sadly).
i have a quote for OME 777 - front, OME - 108 - rear, and ARB 150107 springs, and OME SD02 damper for 425 w/ tax from local 4 Wheel parts shop. Is that a good way to go? Any issues matching to the rear springs that are already there?
thanks!
matt
thanks!
matt
ellebarto
Sights N Sounds
05-21-2013 09:35 AM
FordCrusherGT
01-27-2007 08:09 PM
