Shock/Spring Replacement Question
Old Nov 8, 2009 | 01:16 PM
mherson's Avatar
Default Shock/Spring Replacement Question
good afternoon.
i have a 2001 disco with 150K miles on it.
when i bought it the rear left bag was leaking and i was scared of chasing the issue so i did the strutmaster conversion on rear.
the 4 shocks and the 2 front springs look like original.
can someone advise on the following:
do i need any 'special' specs on front spring to make sure they match the strutmaster rear? what are the recommended shocks (light, med, heavy) if 95% of use is on-road (sadly).
i have a quote for OME 777 - front, OME - 108 - rear, and ARB 150107 springs, and OME SD02 damper for 425 w/ tax from local 4 Wheel parts shop. Is that a good way to go? Any issues matching to the rear springs that are already there?
thanks!
matt
Old Nov 8, 2009 | 01:48 PM
Matt, send me your number before you go to far or you'll end up with a very unbalanced truck.
Old Nov 16, 2009 | 09:03 PM
mherson's Avatar
Mike,
I will PM my number.
In the meantime, can you or anyone else on the forum post a suggestion? I am not too eager to replace the rear Strutmaster spring as they are brand new so want to get something to match.
thanks
Matt
jdg52
Nov 19, 2010 10:42 PM
avking
Jan 23, 2009 08:27 PM
discotx
Apr 17, 2008 11:41 AM
FordCrusherGT
Jan 27, 2007 08:09 PM
