short block swap (no spark)
Old Oct 7, 2010 | 05:55 PM
Arizona man's Avatar
Default short block swap (no spark)
On my 2002 disco II I just finished transferring everything off my old 4.0 block with multiple slipped cylinder liners to my new 4.0 block. Dropped the engine in the truck 2 days ago, finished connecting everything last night. After I filled up the oil and coolant I went to start it for the first time and found that I'm getting no spark. It sounds like it was attempting to turn over a little bit weak. Any ideas?
Old Oct 8, 2010 | 07:58 AM
Check and see if you damaged the crank sensor or connection.
Make sure to prime the oil pump before starting.
Old Oct 8, 2010 | 10:25 AM
Ok thanks. I was going to start with the crank sensor then try coil packs.
Arizona man
Jun 21, 2010 07:54 PM
tornado_735
Nov 23, 2009 03:09 AM
jkimble
Jul 21, 2009 04:12 PM
Jst4fun
Aug 17, 2007 10:35 PM
rinmud
Aug 12, 2006 07:12 PM
