Should I?
Old Feb 6, 2011 | 01:28 PM
WindrockRover's Avatar
Default Should I?
I'm replacing my head gaskets this week. Was happy to see that the heads and valves were good, minus a little work.
I got them back from the machine shop on Friday and all I'm waiting on is to order my parts.
While I have it apart, should I go ahead and replace the water pump? My DII has 135,000, and it still has the original pump.
Anything else I should do while I'm at it?
Old Feb 6, 2011 | 01:48 PM
It wouldnt hurt, replace all radiator hoses too and of course the plugs and wires.
Old Feb 7, 2011 | 08:59 AM
Bundu's Avatar
Banned
Water pumps have a bad habit of crapping out right after you put everything back together.
Old Feb 7, 2011 | 09:07 AM
sloan74's Avatar
X2 with Bundu. I would do the pump. Especially the gasket for it. I need to do mine this summer. Replace the serp belt also while your at it. Cheap for new belt.
Old Feb 7, 2011 | 09:10 AM
Make sure you replace the t/stat, plug wires, coolant pressure cap, change over to either the yellow or green coolant and add either a bottle of Purple Ice or Water Wetter.
If you want a good deal on the gasket set as well as the other parts, go to my signature section and contact Will per his link.
thompson
Jul 9, 2013 05:52 AM
mikemeyer0
Off Topic
Aug 24, 2005 01:53 AM
jstrau10
Jul 31, 2005 02:46 PM
thansaffel
Mar 18, 2005 04:38 AM
natedog437
Feb 23, 2005 05:14 PM
