Should I buy this
Old Jan 19, 2010 | 04:05 PM
sdog21's Avatar
5th Gear
Default Should I buy this
Hey everyone.... Ive been searching hard for a good landrover... found a couple of good deals, but got beat to them. I want a good project/off road car. Ive done things like swapping a transmission and a transfer case, replacing a fuel pump and some axle shafts.
Would this be a good buy? 2000 Disco, all systems function, has roof rack, lights, brush gaurd. Stuck in "limp mode" 1st gear will not work, starts fine in 2nd gear and drives at high speeds fine, m & S lights are on.
Hes asking 2,500 it has 129K miles on it
Just needs wiring check??? new tranny? what do you guys think... i want to act quick
Old Jan 19, 2010 | 04:21 PM
meltdowndave's Avatar
It could be as simple as a bad alternator or dead battery.
But having experienced the same thing, my money is on a bad WXYZ switch. It can be fixed in 45 minutes for $125 or so if you buy a used part.
With that mileage, though, be ready to replace your head gaskets. Also make sure to do the 60,000 tune up. You can do both for $700 or less if you perform the work yourself.
Old Jan 19, 2010 | 04:30 PM
JHDisco2's Avatar
Where are you located?
Old Jan 19, 2010 | 04:52 PM
sdog21's Avatar
5th Gear
thanks....im in houston... any ideas on price of a used tranny if it turns out to be the culprit
Old Jan 19, 2010 | 05:38 PM
sdog21's Avatar
5th Gear
I have a code reader and have found from reading on here that p0722 indicates a bad switch, so im hoping it will throw that code when i go to buy it. does anyone know what codes would indicate something wrong with the transmission itself?
Much Thanks!! you guys are a GREAT knowledge base!
Old Jan 19, 2010 | 06:24 PM
Serious tranny problems would generally require a special code reader available at, you guessed it, your LR stealership.
General codes, though, can be read with an OBD2 scanner.
Doing a quick search should get you what you need.
The tranny is a Mercedes make, I believe. They are generally pretty solid...probably the most reliable part of truck.
Old Jan 19, 2010 | 10:22 PM
JHDisco2's Avatar
I'm in Katy and I have guy with a good tranny if it comes to that. I will check and see if he has sold it yet.
Jeff
Old Jan 19, 2010 | 10:39 PM
Mrmerlin's Avatar
if you can go to NAPA and buy a BLOCK tester ( 50.00) this will let you know if the engine has a leaking headgasket or cracked head.
Then you make an informed decision, and it can save you hundreds of dollars
Sobi Mobile
Mar 28, 2006 02:28 PM
furyphoto
Jan 13, 2006 02:02 PM
tymecard
Sep 27, 2005 10:41 PM
RangeRoverPDX
Sep 23, 2005 07:04 PM
thansaffel
Mar 18, 2005 04:38 AM
