Should I regrind my crankshaft?
Old Sep 24, 2019 | 09:49 PM
Bal D Correa's Avatar
Default Should I regrind my crankshaft?
Hello guys,
I'm still working on my first BOSCH V8 4.0L engine rebuilt for a 2000 Discovery II. I'm done with the cleaning of the block.
I'm about to put the crankshaft back on and replace the main bearings, but before, I did take some measurements. There is no run-out on it and the diameter of the main bearing journals are inside the parameters 2.449 to 2.52 in as the overhaul manual states. My concern is with the conrod bearings journals. All of them measured in average 2.183 to 2.184 in.
On the manual the diameter for using standar bearings are 2.20 to 2.22 in and the under size 0.01 are 2.17 to 2.18 in, so I'm in the middle. Should I take the crankshaft to the machine shop and have them regrind to the undersize range or can I just use the standar bearings?
Thank you.
Old Sep 24, 2019 | 11:16 PM
No Doubt's Avatar
I ground the crank to the maximum .02 and then used the .02 oversized main and connecting rod bearings on the theory that:
#1: less rotating mass is better, and
#2: my machine shop would deliver a more perfect crank than what came new from LR.
...but, there's also something to be said for spending as little as possible on these vehicles, so I get the flip side argument.
Old Sep 25, 2019 | 06:08 AM
Jason Feuerstein's Avatar
Originally Posted by Bal D Correa
Hello guys,
Thank you.
If you already have the crankshaft out, getting it turned shouldn't be particularly expensive. I would go ahead and use the undersize bearings.
Old Sep 25, 2019 | 06:47 PM
Thank you for the help guys. I'm taking my crankshaft and heads to the machine shop tomorrow. I think I will go for the 0.20 size.
Old Oct 15, 2019 | 07:44 PM
Hello guys, today I got my crankshaft back. I did a 0.010 cut on the main and conrod journals. Now I'm facing a huge struggle finding the right size bearings and it's driving me crazy.
I have been mainly purchasing my parts from E-bay and I just can't find any set that meets the undersize 0.010" or 0.25mm. Mostly are standar, 0.10 or 0.20, but they don't specify if oversize or undersize and neighter if that is mm or inches.
https://rover.ebay.com/rover/0/0/0?m...2F183435533281
https://rover.ebay.com/rover/0/0/0?m...2F182897987841
The only one that looks that may be the right size are these ones, but it is only the conroad bearings and haven't found anything for the main.
https://rover.ebay.com/rover/0/0/0?m...2F352521631103
I would really appreciate any help understanding what they mean with size .20 or .10 or if there is a place where I can buy a set that is not based in England and would take weeks to get the parts.
Old Oct 16, 2019 | 06:30 AM
I believe most of the bearings you can buy off the shelf for a Rover V8 are oversize bearings. I would give King Bearings a call.
Bal D Correa
Sep 23, 2019 09:00 PM
Bal D Correa
Sep 23, 2019 08:58 PM
NorCalDisco
Jan 28, 2016 05:46 AM
BCDisco2Lando
Jan 9, 2014 06:56 AM
Grlica
May 1, 2013 06:13 PM
