Should I replace this timing cover?
This cover has 107k miles on it. No dash lights, has worked fine
The tolerances check out, however I've managed to ding up the oil pump housing pretty good while wrangling the relief valve out. The gouge is maybe 5-10 thou deep ( you can see it in the photo running parallel to the pressure relief hole.
I have a new oil pump gear ready, but the width on the inner rotor is a thousandth less than the 107k used gear... Hmm that's weird (bought from AB)
Rather than mess with trying to find new relief valve o-rings, and given the above information... I'm considering just buying a new cover from Turner for $300.
Thoughts?
Thoughts?
Turner is the seller: 4.0V8 Front Cover & Oil Pump - Land Rover Engine Parts
Their prices are good (limited selection of engine parts only) and they also do quality control on everything they sell.
I'm leaning towards a new cover, but I will think it over and try filing first. $300 isn't really worth the risk to me in having a potential low oil pressure or pump blowup problem.
In other news, the rebuild has begun. Crank is torqued down. 54 foot pounds was a lot easier than I thought it would be - what is 54 lbs supposed to feel like? The bolts only moved maybe 60 degrees from 10 pounds to 54.
I might smooth that out, but I might ignore it completely. That's pretty minor IMO.
With regard to 54 ft-lbs - that's not much; it should feel like you didn't crank it down. If it's the correct torque value (I'm sure it is, I just haven't checked the RAVE), you did it right. You could easily exceed 54 ft-lbs with regular hand tools.
Jeff Blake (11-21-2016)
I will.
You probably know the prominent groove is machined and normal. The other light scouring as other suggested is not likely to cause OP issues. I've seen others ask your question here with images that may warrant cover replacement.
I'm not a LR specialist as most have responded are not and don't claim to be. Also not one to spend mine or a customers $s when not necessary. If a new cover/pump assembly gives you a greater piece of mind and you have the liquid funds available, replace it.
Martin Rodriguez
02-25-2014 08:55 PM
texmbr
01-25-2011 01:19 PM
