Should just buy new block/liners
Bought my truck as a project, had 122k and a blown headgasket. It was leaking between cylinder 8 and the water jacket. Simple fix, no need to throw money at a problem that doesn't exist. Dismantle and inspect first.
I'm new to this forum but I'm sure there are a million opinions out there. I personally used the Victor Reinz set as I have always had great luck with them on all my older European cars. Their head gasket is composite material with steel reinforced head bolt and cylinder bore holes. Make sure that you replace the head bolts as well, I prefer the Beck Arnley set. I also suggest that you soak the bolts in oil for some time before install. That's something I always do when working with aluminum to ensure I get an accurate torque spec.
Just to put this out there, my shop specializes in European vehicles. I'm in LA so we work on a lot of land rovers. We probably do five or six valve jobs a year on discoveries due to blown head gasket's. I have never seen a cracked block or slipped liner.
carid
Member Group And Special Buys
Mar 12, 2015 10:24 AM
Blakesrover
Feb 21, 2013 01:43 AM
DooFlotchy
Dec 4, 2011 05:09 AM
JBEGIN
Jun 27, 2009 12:38 PM
