Shoulda put that shield back on...
Old Nov 14, 2017 | 08:29 AM
robert.juric's Avatar
Default Shoulda put that shield back on...
Aww man, just when I thought I was out of the woods. I left out the fan shroud shield on the top and the fan blade cut a hole in the very top hose. From the bleed valve to the top of the radiator.
So does anyone know if its possible to buy just this hose at a local parts store? Is it possible to use a generic hose? I really don't want to spend $60 for the entire upper assembly.
Old Nov 14, 2017 | 08:57 AM
OverRover's Avatar
Sucks, but at least you have a nice straight bit of hose to work with. IDK of a single replacement hose, but there is an option.
If you want to save $60 for now go to NAPA or any auto parts store and get a 1 1/4" hose repair splicer and 2 clamps. They come in kits or singles(I like the galvi steel ones) and for about $10 you are back to HAPPY TOWN!
> https://www.summitracing.com/parts/sum-380600/overview/
Old Nov 14, 2017 | 12:44 PM
dgi 07's Avatar
This..
Old Nov 16, 2017 | 02:54 PM
OffroadFrance's Avatar
Duh, who's the Harry Throttle guy anyways
"For the things we have to learn before we can do them, we learn by doing them...
Aristotle"
I bet you wished you had something different for your signature line
If it were me in the I would go with the Over Rover solution, certainly saves you some dosh.
Old Nov 16, 2017 | 03:19 PM
I sucked it up and bought the hose assembly. Bleh.
I have noticed an intermittent belt squeal when cold in the morning now. Its intermittent because it sounds like a bad spot on the belt or something that only makes a noise at one portion.
I'm sure it has something to do with either removing the jockey and PAS pulleys or getting coolant on a different part I didn't spray off. After it warms up it seems to go away. Since it wasn't there before and has persisted for 2 days I have a slight concern about it.
Old Nov 16, 2017 | 05:55 PM
Motorhead1's Avatar
A small belt squeal is common after an anti freeze leak, It will probably go away...
Old Nov 18, 2017 | 10:00 PM
Southern's Avatar
I got one of these and am still running it after an unknown number of thousand miles ( a lot).
Wasn't expecting much, but seems to work.
Amazon Amazon
Old Nov 18, 2017 | 11:04 PM
OverRover's Avatar
https://www.amazon.com/dp/B0066SULQS...d=Z4G9BMAM5YGO
OMG URO Parts hoses give me the shakes! I've seen so many fail it's crazy.
Lets hope you got one from a healthy batch. Good Luck!
san988
Oct 13, 2013 03:05 PM
demonlarry
Off Topic
Sep 5, 2009 09:11 PM
mcrw
Jan 29, 2009 07:48 PM
mighty
Oct 10, 2007 02:21 PM
apcollin
Sep 12, 2007 05:23 PM
