Silicone spray?
Old Mar 11, 2007 | 11:45 PM
mowthat's Avatar
Default Silicone spray?
Does anyone use anything on their airbags to keep them quite like a silicone spray or some sort of rubber rejuvinator? Maybe something for the bushings as well.
Thanks
Jake
Old Mar 12, 2007 | 03:18 PM
Default RE: Silicone spray?
Jake, are you saying your air bags actually make noise?
Mike
Old Mar 12, 2007 | 03:56 PM
mowthat's Avatar
The only noise they make is whenthe suspension is compressed, like going over a speed bump, they make alittle noisethrough the travel of compression and expansion. This may be normal, in which case I will forget about it, but if there is something for rubber id like to know.
Old Mar 12, 2007 | 05:51 PM
The only noise you should hear would be during the time to compressor cycles on or when you get out of the truck and the unit bleeds of a little air pressure to off set your weight as you get out of the truck.
Mike
Old Mar 12, 2007 | 06:00 PM
mowthat's Avatar
yea this is something else. I hear the compressor cycle and I also hear the it level out when it releases air. They seem to work well, maybe this is something else back there. I'll have to take a closer look.
Thanks for the input.
Old Mar 13, 2007 | 10:30 AM
If you don't find the problem, send me your tele number and a good time to call, we can talk thru it.
Mike
urq
Mar 9, 2012 07:43 AM
garrytd4
Feb 10, 2012 01:38 PM
LRD2&ME
Aug 15, 2011 05:54 PM
EstorilM
Dec 14, 2010 08:33 AM
Willie00d2
Feb 18, 2010 11:33 PM
