Silly question about the interior lights and the rear door.
I'm shocked to find myself asking this, but: how does the truck know when the back door is open? I was expecting to find a frame switch like every other car, but nothing… is it in the closing mechanism somehow? Is it just hidden somewhere and I'm being dense?
Mine has stopped turning the interior lights on (probably because it's close to absolute zero out).
Just so surprised to find it isn't obvious.
Oh Land Rover, why must everything be just that little bit more difficult than necessary?
It's a secret ![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
This may help you TD5 Door microswitches
There are no push type switches at all on a D2 it's all controlled via the BCU (body control unit) when the door is opened and is activated by the door lock mechanism. Bl@@dy progress for ya
these are via the BCU controller and the remote key fob initially and latterly when each door is opened or closed. You can activate each light individually with a switch on each light.
I've fitted LED festoon lamps to all lights so if I leave an internal light on accidentally for a few days the battery doesn't totally discharge.
Thanks OffroadFrance. Glad I wasn't just loosing my mind. Seems to have worked it's self out, probably just frozen.
Another dumb question I had while driving in the strange arctic conditions last night: my review mirrors suddenly fogged up. I have the heated ones (although I think only one actually works because Land Rover). How do you turn them on? I've had them come on when I hit the auto defrost, but never had the need when just driving along.
I assume either the heated windscreen or the rear defrost, but could be wrong.
These really are my most remedial questions, I know.
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
These really are my most remedial questions, I know.![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
The NA spec may be different but mine is an export LHD spec originally destined for south Americas (cancelled order that's why I was sold it cheaply by the main dealership 33% discounted on RRP)
