Silly question about the interior lights and the rear door.
Old Jan 14, 2015 | 12:22 AM
Fallstaff's Avatar
Default Silly question about the interior lights and the rear door.
I'm shocked to find myself asking this, but: how does the truck know when the back door is open? I was expecting to find a frame switch like every other car, but nothing… is it in the closing mechanism somehow? Is it just hidden somewhere and I'm being dense?
Mine has stopped turning the interior lights on (probably because it's close to absolute zero out).
Just so surprised to find it isn't obvious.
Oh Land Rover, why must everything be just that little bit more difficult than necessary?
Old Jan 14, 2015 | 05:54 AM
OffroadFrance's Avatar
It's a secret
This may help you TD5 Door microswitches
There are no push type switches at all on a D2 it's all controlled via the BCU (body control unit) when the door is opened and is activated by the door lock mechanism. Bl@@dy progress for ya these are via the BCU controller and the remote key fob initially and latterly when each door is opened or closed. You can activate each light individually with a switch on each light.
I've fitted LED festoon lamps to all lights so if I leave an internal light on accidentally for a few days the battery doesn't totally discharge.
Old Jan 14, 2015 | 06:45 PM
Fallstaff's Avatar
Thanks OffroadFrance. Glad I wasn't just loosing my mind. Seems to have worked it's self out, probably just frozen.
Another dumb question I had while driving in the strange arctic conditions last night: my review mirrors suddenly fogged up. I have the heated ones (although I think only one actually works because Land Rover). How do you turn them on? I've had them come on when I hit the auto defrost, but never had the need when just driving along.
I assume either the heated windscreen or the rear defrost, but could be wrong.
These really are my most remedial questions, I know.
Old Jan 15, 2015 | 04:29 AM
Hi Fallstaff, the heated windscreen or rear screen defogger turns them on, well at least mine does. Bearing in mind the heated windshield, by design, turns itself off after a period of time probably due to conserve the power consumption or potential damage to the glass.
The NA spec may be different but mine is an export LHD spec originally destined for south Americas (cancelled order that's why I was sold it cheaply by the main dealership 33% discounted on RRP)
adam123
Jun 21, 2011 11:48 AM
maxman
Nov 29, 2010 12:31 AM
ScottinNJ
Oct 28, 2007 09:02 AM
JKK
Oct 13, 2005 01:27 AM
Evian
Aug 18, 2005 11:52 PM
