Simple off road lights?
Old Aug 3, 2007 | 03:33 PM
SpeedAgent's Avatar
Default Simple off road lights?
What is the easiest way and least intrusive way of installing a pair of off road lights? I don't want to spend $500+ on a front brush setup, at least right now. Is there anything out there that is not as big and expensive? I haven't seen anything, but thought maybe you guys might know of something.
Thanks,
Chris
Old Aug 4, 2007 | 02:09 PM
97discoI's Avatar
4wd High
Default RE: Simple off road lights?
A friend of mine used to have a pair of lights that bolted onto the front fenders of his jeep. At the rear top part so that they were essentially in front of the side mirrors, far enough out so that they didn't block the hood from opening. I've never seen anything like that on a Land Rover, but it's something to consider. It would probably be possible to have someone make you a pair of brackets for a reasonable price if there's nothing commercially available.
Old Aug 4, 2007 | 03:15 PM
If you pull off your front bumper, find a spot that works, drill a couple of holes and put a little support on the lower side of the hole you can mount a couple of lights.
What year is your truck?
Mike
thehun
Dec 27, 2010 03:41 PM
Chrisinhouston
Jun 24, 2008 04:15 PM
tailchaser0527
Dec 5, 2007 08:51 AM
iJeremy
Nov 1, 2006 11:49 AM
hymlopez
Mar 23, 2006 11:29 PM
