Sitting On The Diagnostic Tool Fence?
-(minus) meant to indicate savings compared to a US vendor's current pricing.
Current price from UK should be about $350 delivered etc.
I found the Britpart site somewhat lacking for info and ease of navigating compared to info directly from Lynx. My understanding is Lynx develops/produces and Britpart has a marketing agreement?
Lynx Diagnostics
Lynx Diagnostics
Lynx Diagnostics
Lynx Diagnostics
Continental Corporation -Continental takes over diagnostics specialist Omitec
Pound down more, as of 10-10-16 should be about $335 shipped for the Lynx.
https://www.lrdirect.com/DA6430-Brit...keep_https=yes
I have a Hawkeye that I'm very happy with and it has the brake bleed function. I also have a scangauge II that will read codes, but I think it will only clear the powertrain codes and not the other systems. Its a nice little gauge for keeping an eye on mpg and temp and clearing P0--- codes.
Good choice, I use a Lynx with a tab and it gives you everything you'll need on a D2 and some other later LR's. Take advantage of the weak sterling at the moment and get one cheap.
The lynx has functioned well for me as a code reader, but I've been really disappointed with Britpart's lack of customer support and the Lynx's lack of accessibility in regards to what they claim are its programming functions: https://landroverforums.com/forum/ge...ailures-82623/
My experience is that you won't be able to use the Lynx's programming function without some 18-digit mystery code that neither Britpart nor Land Rover can/will identify. I'd go with the tried-and-true.
Are you refereeing to the 18 digit code required to program keys? As far a s Know most if not all key programing capable devices need the 18 digit key code. When you buy a brand new key from the dealer it come with the 18 digit code for that key. When you're using an old key that you're trying to program to a new car and you don't have the 18 digit code there is a nice forum member who developed a spreadsheet that uses the code on the back of the key to create a new 18 digit code. I have successfully used the spreadsheet and lynx to reprogram old keys to my d2.
https://docs.google.com/spreadsheets...uyU/edit#gid=0
