slight stumble at idle
My 04 D2 has a slight stumble at idle. It idles at 750 rpm, over 800 rpm it smooths out. I’ve replaced, plugs, wires and coils. Compression is good, leak down test…ok I checked for vacuum leaks, found none, I’ve cleaned the MAF and ran injector cleaners ( Techron and Lucas) several times.
Your thoughts
Thanks
Your thoughts
Thanks
Spencerfitch
06-08-2010 12:41 AM
