Slight whirring/humming sound when accelerating, plus other issues
Old Sep 13, 2010 | 01:02 PM
HelenaRover's Avatar
Default Slight whirring/humming sound when accelerating, plus other issues
I've had my 99 disco II for a couple weeks and just this weekend started hearing this sound. In other vehicles I've owned, a loud whirring or vaccuum-like sound means transmission issues, but this sound is more quiet and only noticeable with the radio off. It's coming from the front half of the truck.
I got under her last night and found a little oil seepage from the sump and what I think is an access panel on the transfer box. I park in the same place everyday and have yet to see any spots... the front two crossbars that pass under both these areas show signs of a drop, though.
What's your opinion?
Old Sep 13, 2010 | 01:17 PM
hilltoppersx's Avatar
are you throwing any CEL codes? are you losing coolant?
Old Sep 13, 2010 | 01:35 PM
sloan74's Avatar
sounds like your driveshaft. be careful man. what does the ujoints on the front drive shaft look like? are they lose or binding? its recommended you change them out asap and replace them with greasable ones.
u can fix the wet xfer case cover by removing it, cleaning it, and resealing it with fresh rtv. dunno about the oil sump.
________
Ford d2c platform history
Old Sep 13, 2010 | 02:01 PM
I read a couple other threads... it's definitely a driveshaft issue.
Next step, fixing it thing. Any parts need to be special ordered for my disco or does any reputable place carry the greasable u-joints, etc?
Old Sep 13, 2010 | 02:09 PM
(qty 3) 344 precision u joints (qty 1) 617 precision ball kit or if you have an Advance Auto nearby PDQ 1-0005 (qty 3 @ $14) and Neapco 7-0081NG (qty 1 @ $30) there is a thread on here to rebuild it yourself. or you can have a drive line shop do it with these part numbers. drive line shop should cost about $200. or you can buy a new tom woods for around $350
Old Sep 14, 2010 | 11:17 AM
Thanks for all the advice... what a great LR community.
Hilltopper, I searched for 1-0005 on Advanced Auto and came up with squat... what is it?
Old Sep 14, 2010 | 11:39 AM
Bundu's Avatar
Banned
Neapco universal joint part #1-0005 $ 12.49
All the info is here: https://landroverforums.com/forum/sh...ad.php?t=29302
Old Sep 14, 2010 | 11:43 AM
Thanks for that.
ngarover
Jan 2, 2013 08:31 AM
xmc
Jan 12, 2012 08:12 PM
xmc
Jan 10, 2012 08:36 PM
Snafu / Disco Fries
Apr 13, 2011 05:40 PM
larryrover
Jan 15, 2008 09:48 PM
