SLS Compressor
SLS Compressor
So my SLS airbag suspension is breathing its last days and I am going to convert to springs. I have found the kit I want and have read up and watched several videos leading me to believe I can do almost all of it by myself. However, I find that the SLS Compressor will have to be turned off by the dealer. Is there anyway I can get that thing turned off without taking the Landy in?
"I" would just disconnect the electrical plugs going into the side of the compressor under my truck? I'm sure you and also pull fuses and relays, but I would would try the easy first; it's also the easy to reverse. The compressor is mounted in a box under the truck below the drivers seat.
smokin
09-06-2013 01:19 AM
EstorilM
05-24-2010 11:03 PM
EstorilM
12-30-2009 09:56 AM
2000, 2004, compresser, compressor, disable, discovery, discoverys, fuse, land, location, relay, relays, rover, sls, turn
