SLS Compressor
So my SLS airbag suspension is breathing its last days and I am going to convert to springs. I have found the kit I want and have read up and watched several videos leading me to believe I can do almost all of it by myself. However, I find that the SLS Compressor will have to be turned off by the dealer. Is there anyway I can get that thing turned off without taking the Landy in?
you can turn the compressor off but you will get SLS waring lights, either the dealer or someone with a bearmach Hawkeye scanner can set your BCU to see your truck as a coil spring unit, that will shut off all the SLS stuff without having warning lights. Hope this helps.
"I" would just disconnect the electrical plugs going into the side of the compressor under my truck? I'm sure you and also pull fuses and relays, but I would would try the easy first; it's also the easy to reverse. The compressor is mounted in a box under the truck below the drivers seat.
there are fuses and relays but why not leave them in tack, you never know what else could be on those fuses and relays. Just pull the plugs, take out the two bolts off the compressor and ship it off to me as a spare.
smokin
Sep 6, 2013 01:19 AM
EstorilM
May 24, 2010 11:03 PM
EstorilM
Dec 30, 2009 09:56 AM
2000, 2004, compresser, compressor, disable, discovery, discoverys, fuse, land, location, relay, relays, rover, sls, turn
