SLS Problems
Old Apr 14, 2008 | 12:40 PM
ccombrink's Avatar
Default SLS Problems
Hello everyone,
I have been working on my disco here for the last few weeks trying to figure out exactly is wrong. I am thinking my SLS compressor is on its way out. It will fill up the supension and work for awhile. Normally if I take it out for a drive withing a few miles the light comes on and the suspension starts to drop. So basically it has been here parked at my house.
Is there anytest or things that I can do on the SLS compressor that will let me know if it is acutally dead. Also I have the rave manual but I still havent figured out where the pump is. I have checked the airbags for damage and they look to be in good overall shape.
Any help would be appreciated.
Thanks
Old Apr 15, 2008 | 08:46 PM
Default RE: SLS Problems
I have heard that the pump is under the pass seat, but I dont know for sure. I would bet more on a air leak than a bad compressor.
You can get a coil conversion for around $1000 and depending on what it wrong it might be cheaper. And is a onetime fix.
Old Apr 15, 2008 | 09:01 PM
roverguy7's Avatar
it sounds like you either have a bad height sensor, or possibly a bad valve. comp will not cause it to drop when engine is running. need to have codes pulled from ABS to know for sure.
[/align]
Old Apr 15, 2008 | 09:34 PM
rphotographer's Avatar
I had the same thing happen, my disco looked like a low rider....the compressor was out..it is located right under the car on the drivers side, about where the seat is. my mechanic found a used one with a warrenty.. cost me about 500.00 installed.
Thanks
Ralph
www.ralphduke.com
Old Apr 16, 2008 | 07:33 AM
When you get ready, call me and I will walk you thru what to do to get it running correctly again.
303-862-7680
Colorado before 8 pm
Old May 13, 2008 | 06:22 PM
ccombrink's Avatar
Well first of all I would like to thank Disco Mike for all of his help on this problem. I have tried pulling the ride height sensors and moving them to see if they where the cause. Luckily while I was trying to pull one off the problem reappeared and the suspension dropped.
I noticed that the pump would make a clanking sound like it was stuck or jammed. I think that is where my problem is. I moved the sensors and nothing it never came back. So I called a local rover shop and they are going to pull the codes for free. I just have to get it to SLC. I will post the codes when I get it down there this week.
They are also telling me I should convert to the coils on the rear and forget the repair of the SLS system. I am not 100% I want to do a conversion.
Thanks once again for the great help.
Old May 13, 2008 | 08:09 PM
ccombrink's Avatar
I was surfing the internet and I found this forum.
http://www.landyzone.co.uk/lz/f8/sls...amp-47390.html
This guy had the same problem that I have. So it looks like it is the pump. Does anyone have a used one laying around that they are willing to sell?
Thanks
Old May 13, 2008 | 08:15 PM
Call, http://www.roverlandparts.com/ , see if they have one, other wise post on both the Lamd Rovers Only and the LRRF and you should find one.
masonchard
Aug 18, 2012 08:12 PM
buick215
Oct 20, 2011 02:43 PM
buick215
Jun 17, 2011 01:31 PM
DiscoIIBrandon
Feb 21, 2011 03:09 PM
