SLS stuck in high position (offroad)
Old Jan 6, 2014 | 06:58 PM
toad2's Avatar
Default SLS stuck in high position (offroad)
Has been for a couple days. I thought it was froze maybe ( 2 weeks of -20 to -25) but everything looks fine. Just won't go down.
Any suggestions? Disconect the battery to reset the slabs? Can I manually release some air?
Thanks in advance.
Chris
Old Jan 7, 2014 | 12:25 AM
Dane!'s Avatar
try driving it over 30mph in a safe area, it should automatically go down. Is your off road mode light still on?
Old Jan 7, 2014 | 07:03 AM
acamato's Avatar
You can try to release some air by loosening the hoses, that feed the bags, at the compressor. If the off road mode light isn't lit, The problem may be your ride height sensors.
this thread has a photo of which ones to loosen: Disco II Air suspension – the definitive guide - Land Rover Zone
Old Jan 7, 2014 | 07:17 AM
toad2's Avatar
Drove it to the airport yesterday, 60mph for 30 min. No change.
No, the offroad light is not on.
Old Jan 7, 2014 | 07:29 AM
dusty1's Avatar
I like sensors as well.
Old Jan 7, 2014 | 07:34 AM
toad2's Avatar
So, can I change a sensor without going to a dealer(4hrs away)? I have a parts truck with sls. If I marked exactly where the old 1 is and put the new 1 in the same spot?
Old Jan 7, 2014 | 10:12 AM
dusty1's Avatar
not sure on replacement. I am more of a break it and yank it practitioner, when it comes to sls. I have had sensor problems, but......trash can fixed mine. no help, i know. sorry
are you getting any dash lights that might point to relays/fuses? truck with arrow behind it?
Old Jan 7, 2014 | 10:41 AM
toad2's Avatar
Pass side sensor siezed where conected to radius arm. Removed bottom section from knuckle down, replaced with 1 from parts truck, bled down air. Seems 2 b workin now.
Thanks for the link, had a good pic of the compressor parts.
Thanks guys.
Old Jan 8, 2014 | 04:59 PM
toad2's Avatar
Also the sensor on drivers side was not working when i got a buddy to read the codes for me.
Replaced the top half with the 1 from my parts truck and now seems to be cured.
Fingers crossed!!
ImQuattro
May 1, 2014 08:36 PM
Lance Bennett
Aug 30, 2013 07:34 PM
EstorilM
Dec 30, 2009 09:56 AM
EVN137
Sep 14, 2007 08:21 AM
