SLS won't stop beeping. Fuse questions
Old Nov 8, 2017 | 05:51 PM
RUSTANDRUBBER's Avatar
Default SLS won't stop beeping. Fuse questions
So I did the coil airbag swap. Pulled the #5 and #9 fuse in the main fuse box. Unplugged the air compressor. I'm having the beeping going off every time I drive it. I see that the fuse #28 in the fuse box inside is for abs\sls will pulling this stop the beeps. Any side effects to the abs I should look for? Or am I on the wrong path here? Oh and the 3 amegos are still on. Planning the rewire mod for this next, need to have the codes read first.
thanks in advance.
99.5 disco 2 no ACE
Old Nov 8, 2017 | 06:14 PM
mln01's Avatar
Fourth question on this topic in three days. You need to have the air springs/coil springs setting changed in the SLABS computer. Or, get a SLABS computer already set for coils - ~$40. Plug and Play.
Old Nov 8, 2017 | 08:30 PM
Best4x4's Avatar
Also remove SLS relay from under the hood fuse block.
Old Nov 9, 2017 | 01:50 PM
Default thanks so much
so i should of grabbed the SLABS when i pulled the springs at the pull a part. got them for 30 bucks so i am still on top for now. turns out they are a strut masters kit. always a good time at the pull apart. will look for the relay also.
j
Old Nov 9, 2017 | 02:41 PM
Best4x4's Avatar
j
I’d go grab the slabs unit. Can’t hurt & it’s PNP so then just slap yours on Ebay with a good description including SLS Enabled & you’ll get your $$ back.
CapeRover
May 3, 2013 04:35 PM
FLDiscoII
Sep 8, 2012 11:19 PM
DPR81
Feb 3, 2009 05:13 AM
