Small Alternator Connection with Captive Nut - Source for a replacement?
Old Jun 15, 2015 | 11:34 PM
TripleThreat's Avatar
Default Small Alternator Connection with Captive Nut - Source for a replacement?
The small connection on the back of the alternator on my DII has a ring type terminal with a captive nut connected to it. I damaged mine when removing it and the wire broke off. Rather than just using a simple ring terminal, I'd like to replace it with the factory connector with the captive nut... Anyone know where I can source one?
Old Jun 16, 2015 | 12:35 PM
acamato's Avatar
Try Paul Grant.
They are called a captive nut terminal. I can only find them sold in the UK.
Captive Nut and Ring Terminals | Dalroad Norslo Ltd
Wiring assembly services and harnesses for looms in the UK
Old Jun 16, 2015 | 11:21 PM
I ended up just purchasing a high quality ring terminal and soldering it to the flat lead off the captive nut. Seems an impossible part to buy. Land Rover Dealership does not have that part even listed.
Old Jun 17, 2015 | 06:03 AM
drowssap's Avatar
a ring terminal and a nylock nut would probably work just as well
Club Cheetah
Jun 9, 2015 04:57 PM
justinthorpe
Nov 27, 2013 02:53 AM
lazerbrains
LR2
May 28, 2013 07:11 AM
mgabriel
Dec 11, 2008 11:53 PM
