Small coolant leak after water pump replacement
Folks,
I am racking my brain. I replaced my water pump a few months ago, along with a new feed hose assy, and I have this annoying small leak which manifests itself on the bottom/ underside of the water pump intake/ inlet. No coolant on top, gasket looks dry, all bolts maintained torque. The pump itself doesn't have any appearance of leaks in the common areas.
I've checked the heater core hoses, the manifold inlet/ elbow. Bottom of the intake manifold is dry. Is there something I'm not looking at?
Thanks for any help that is provided.
Folks,
It sounds ominously like the seal on the pump is duff. Check underneath the pump for water/coolant emitting from the 'tell tale' hole, you'll probably need a mirror. This may be caused by the seal becoming duff or the system over pressurising.
Anyone else got any wisdom to bestow on this humble knuckle-dragger?
The culprit
After closer inspection, the water pump gasket was weeping near the bolt under the intake. I replaced the gasket, and ta-da, no leak. It actually worked out nice because this time I cleaned the 18 years of gunk off the front cover while I had easy access. On to the three amigos........
