Small split within oil tank
Old Nov 13, 2012 | 02:29 PM
Aaron Sandland's Avatar
Default Small split within oil tank
Attached is the picture, I hadn't noticed this before, is this something I should be worried about?
Old Nov 13, 2012 | 07:52 PM
Whats in where?
Old Nov 13, 2012 | 08:51 PM
bballjames's Avatar
I'm pretty sure mine looks exactly the same.
Old Nov 13, 2012 | 10:18 PM
Bkreutz's Avatar
You're looking at the baffle plate inside the valve cover, it's supposed to look like that. Put the oil filler tube back on and you'll never see it again.
Old Nov 14, 2012 | 07:00 AM
Normal and in the future, that is the inside of your valve cover not an oil tank.
Old Nov 14, 2012 | 09:05 AM
Thanks all, yes valve cover my mistake. I was a bit freaked out when I saw that gap.
Old Nov 14, 2012 | 01:23 PM
Here's what is under that baffle. Hope yours are clean, it looks like you can see a part of a rocker arm. Here is a second picture of some that were not, always a good idea to change oil.
Attached Thumbnails Small split within oil tank-100_0313.jpg   Small split within oil tank-eng-1a.jpg
ruffram
Dec 13, 2021 03:44 PM
Externet
Apr 19, 2014 07:46 AM
rrbc
Nov 13, 2009 01:40 AM
Bryan H
Jan 26, 2009 12:08 PM
puchungozback
Apr 24, 2007 06:48 PM
