Smog check threw codes, hoping to know what I need to do
Old Feb 12, 2014 | 02:17 PM
  #21
Jared9220's Avatar
Originally Posted by Joshman
FYI,
Instead of chancing a CHP encounter with expired tags en route to Sac, I elected to try McCoy's in Roseville. They had replaced my wheel speed sensor when I bought it (the used dealer agreed to have it fixed before I bought it), and McCoy's agreed to diagnose both codes for $65 (he has an ABS one that will tell why the P1590 is tripping, and why my EVAP code is on too).
If it is a wheel speed sensor and a evap purge valve, I am assuming both are easy fixes, right?
Yes, both are easy fixes
Old Mar 3, 2014 | 03:52 PM
  #22
Joshman's Avatar
Update:
I changed the evap purge valve with Forman 911-800 and passed SMOG. I am getting a clicking noise now that wasn't there before, but that is detailed in this post.
The mechanic that diagnosed the issues for me is McCoy's in Roseville, CA. great guy, even gave me an amigo he had left over from the days when snap on still didn't support LR. He said that my amigo situation is likely the result of a bad ABS modulator (the thing in the dashboard area), We are looking for one to swap out. Thanks again for the help, guys.
Old Mar 3, 2014 | 04:50 PM
  #23
jfall's Avatar
There is a British recycler off of Sunset in SAC off the 50.
He will probably rip you off but...
Old Mar 3, 2014 | 05:54 PM
  #24
Jared9220's Avatar
A working purge valve is supposed to click. If it is really loud inside the cab, check and make sure the hose that goes to the purge valve isn't sitting up against the firewall and tapping it.
__________________
Old Mar 3, 2014 | 11:30 PM
  #25
jfall's Avatar
Agreed.
Suspend it via the rubber hoses and you will not hear the valve.
Proto31
Feb 6, 2015 02:36 PM
USNAVYORDNANCE
Jan 2, 2015 09:58 PM
jhill15
Feb 11, 2013 01:54 PM
Disco2Guy
Mar 16, 2008 08:40 AM
97DiscoKid
May 30, 2007 04:07 AM
