SMOG FAILED!!! CODES SHOWING UP!! HELP!
Old 08-16-2007 | 10:18 PM
sfxgamer's Avatar
Default SMOG FAILED!!! CODES SHOWING UP!! HELP!
Hello,
I have a 1996 Land Rover Discovery. Just went to get it smogged. It passed the emissions fine but I failed because some codes showed up. p1194-oxygen sensor heater circuit high resistance, downstream sensors---p1191-oxygen sensor heater circuit open circuit, donstream sensor---p0300-misfire??????
Can anyone tell me what these mean and how to fix them? Thanks. any help is appreciated.
Old 08-16-2007 | 10:30 PM
dow's Avatar
dow
Default RE: SMOG FAILED!!! CODES SHOWING UP!! HELP!
get new o2 sensors, plugs, and plug wires
Old 08-16-2007 | 10:32 PM
okdiscoguy's Avatar
How many miles?
I agree with the last post.
Old 08-16-2007 | 10:38 PM
sfxgamer's Avatar
I have 146,000 miles on it. It runs good though! Just need to get those codes clear! Where can I clear the codes?
Old 08-17-2007 | 12:03 AM
dow's Avatar
dow
clear them and they WILL come back almost instantly... you must repair the underlying problem for them to be "cleared"
Old 08-17-2007 | 01:08 AM
dow's Avatar
dow
oh yea, and stop using regular 87 octane fuel
Old 08-17-2007 | 10:05 AM
Your 02 sensors do need to be changed out, once that is done then you can address the 0300 misfire code which could be from cheap gas, bad plugs and or wires and carbon build up.
chaz614
12-13-2011 05:28 PM
philander
08-19-2011 05:20 PM
JEFIII
09-09-2010 12:16 PM
MrBrooks
06-11-2010 10:25 PM
sfxgamer
11-28-2007 08:18 PM
