SMOG FAILED!!! CODES SHOWING UP!! HELP!
Old Aug 16, 2007 | 09:18 PM
sfxgamer's Avatar
Default SMOG FAILED!!! CODES SHOWING UP!! HELP!
Hello,
I have a 1996 Land Rover Discovery. Just went to get it smogged. It passed the emissions fine but I failed because some codes showed up. p1194-oxygen sensor heater circuit high resistance, downstream sensors---p1191-oxygen sensor heater circuit open circuit, donstream sensor---p0300-misfire??????
Can anyone tell me what these mean and how to fix them? Thanks. any help is appreciated.
Old Aug 16, 2007 | 09:30 PM
dow's Avatar
dow
Default RE: SMOG FAILED!!! CODES SHOWING UP!! HELP!
get new o2 sensors, plugs, and plug wires
Old Aug 16, 2007 | 09:32 PM
okdiscoguy's Avatar
How many miles?
I agree with the last post.
Old Aug 16, 2007 | 09:38 PM
sfxgamer's Avatar
I have 146,000 miles on it. It runs good though! Just need to get those codes clear! Where can I clear the codes?
Old Aug 16, 2007 | 11:03 PM
dow's Avatar
dow
clear them and they WILL come back almost instantly... you must repair the underlying problem for them to be "cleared"
Old Aug 17, 2007 | 12:08 AM
dow's Avatar
dow
oh yea, and stop using regular 87 octane fuel
Old Aug 17, 2007 | 09:05 AM
Your 02 sensors do need to be changed out, once that is done then you can address the 0300 misfire code which could be from cheap gas, bad plugs and or wires and carbon build up.
chaz614
Dec 13, 2011 04:28 PM
philander
Aug 19, 2011 04:20 PM
JEFIII
Sep 9, 2010 11:16 AM
MrBrooks
Jun 11, 2010 09:25 PM
sfxgamer
Nov 28, 2007 07:18 PM
