Smoke from Alternator?
Old Aug 15, 2012 | 06:00 AM
Dean's Avatar
Default Smoke from Alternator?
Basically the 2001 Disco 2 has been sitting for a while. As soon as I connected the battery, the alternator smoked. While the alternator is removed, I can connect the battery and everything works fine.
1) Why would the alternator short out and start smoking?
2) If I fix this alternator will the same thing happen?
thanks
Dean
Old Aug 15, 2012 | 06:18 AM
If you just replace the brushes/voltage regulator in the alternator maybe it will work. But if insulation on wires compromised, then problem could repeat. Salvage yards near me get about $29 for an alternator with a 30 day warranty. Also available new, pre-owned from fleaBay, and reputable dismantlers.
If going pre-owned have tested for free at parts store before installing.
The smoking part is most likely a failed voltage regulator, or a bad diode. Indy shop near me (shop manager drives a Rangie, always a good sign) does that for under $100. We have a few write ups on this site for alternator rebuild DIY.
Worst choice would be new from dealer. Next worse is reman from national chain parts stores, because of the high failure rate of Chinese reverse engineered parts. If going this route get the lifetime warranty and carry copy of receipt in truck, you never know where you'll be when it craps out. Mine lasted all of 2 weeks.
Old Aug 15, 2012 | 12:19 PM
Dean's Avatar
great advice...thanks
Old Aug 15, 2012 | 04:48 PM
jfall's Avatar
Get a brand new Bosch or Denso alternator from British Pacific.
About $350.
Never accept a rebuilt one.
If it smoked I would toss it.
If you have lots and lots of time - retired - rebuild it.
If you work - just replace it and move on.
Old Aug 15, 2012 | 05:21 PM
dgi 07's Avatar
Safe to say...it burned out (ba dum ching!)
Old Aug 15, 2012 | 07:06 PM
Get a new Bosch from British Parts of Utah for $265.
JumPeR04
Dec 17, 2009 07:57 PM
tsuami1
Jul 15, 2009 02:28 AM
mgabriel
Dec 11, 2008 11:53 PM
jwmstang
Apr 12, 2007 10:31 PM
Skelly
Nov 14, 2005 10:39 AM
