White Smoke
Old Apr 12, 2007 | 07:58 PM
jwmstang's Avatar
Default White Smoke
I am having white smoke from my tailpipe when I idle it lessens when I drive but it is still there. Also my oil smells like gasoline. Any thoughts. I hope not rebuild or new engine.[:@]
Old Apr 12, 2007 | 08:41 PM
Aquaholic's Avatar
Default RE: White Smoke
What does the smoke smell like?
How's your compression?
You may have washed out your wiper ring - if your compression is good you didn't hurt the other rings.
Or it could be valve guide seals.
Old Apr 12, 2007 | 08:51 PM
Are you low or have you been having to add coolant? If it is not typical condinsation that can show up in the morning then it is possible you have lost your head gaskets.What year is your truck, how many miles on it?
Mike
Old Apr 12, 2007 | 08:57 PM
jwmstang's Avatar
It is a 98 Disco 1 with 100,540miles. The smoke soedn't smell sweet like antifreeze issues it smell a bit like gasoline. As I said the oil also smells like gasoline.
Old Apr 12, 2007 | 10:15 PM
Rover oil smell like gas after 1500 miles, so I wouldn't worry about it.
How about the coolant questions I asked before?
Mike
Old Apr 12, 2007 | 10:31 PM
jwmstang's Avatar
The coolant levels are good. They seem to be normal.
IDAHODISCO
Aug 11, 2009 10:30 PM
Bensun
Jul 22, 2009 04:48 PM
racer11x
Freelander
Dec 24, 2008 09:42 AM
VikingDiesel
Apr 27, 2008 02:45 PM
kraelo
Mar 1, 2008 11:24 PM
