Smoke test - throttle body shaft leak
Old 03-01-2021, 10:55 AM
dswilly's Avatar
Default Smoke test - throttle body shaft leak
So in tracking my O2 code problems (other thread) weather broke and I decided to build a smoke machine and test for vacuum leaks. Smoke machine was successful and for the most part no vacuum leaks which was good. Except for one little wisp of smoke that came out behind where the throttle cables / spring attach. This I would guess is coming out from where the shaft enters the throttle body. Does anyone know if this involves a seal or complete replacement?
Old 03-01-2021, 11:02 AM
yup mine was leaking there as well i never did repair it
Old 03-01-2021, 01:00 PM
dswilly's Avatar
Thanks for the reply. Do you think it had any real impact on the performance? Mine is very slight.
Old 01-26-2024, 11:03 PM
greenrovey's Avatar
it will impact performance as it loses vaccum there
Old 03-08-2024, 07:46 AM
redrover75's Avatar
Default Revival
I have the same wisp of smoke at the pivot for the throttle body. Is there a fix or rebuild kit? Or just let it be? I am chasing a p1415.
redwhitekat
08-16-2019 01:31 PM
vishrb
03-10-2015 06:21 PM
Phant0m
01-06-2014 06:17 AM
caymandrew
05-24-2013 03:12 PM
Robover01
11-27-2009 11:30 PM
Quick Reply: Smoke test - throttle body shaft leak
