Smoke test - throttle body shaft leak
Old Mar 1, 2021 | 10:55 AM
dswilly's Avatar
Default Smoke test - throttle body shaft leak
So in tracking my O2 code problems (other thread) weather broke and I decided to build a smoke machine and test for vacuum leaks. Smoke machine was successful and for the most part no vacuum leaks which was good. Except for one little wisp of smoke that came out behind where the throttle cables / spring attach. This I would guess is coming out from where the shaft enters the throttle body. Does anyone know if this involves a seal or complete replacement?
Old Mar 1, 2021 | 11:02 AM
redwhitekat's Avatar
yup mine was leaking there as well i never did repair it
Old Mar 1, 2021 | 01:00 PM
dswilly's Avatar
Thanks for the reply. Do you think it had any real impact on the performance? Mine is very slight.
Old Jan 26, 2024 | 11:03 PM
greenrovey's Avatar
it will impact performance as it loses vaccum there
Old Mar 8, 2024 | 07:46 AM
redrover75's Avatar
Default Revival
I have the same wisp of smoke at the pivot for the throttle body. Is there a fix or rebuild kit? Or just let it be? I am chasing a p1415.
redwhitekat
Aug 16, 2019 01:31 PM
vishrb
Mar 10, 2015 06:21 PM
Phant0m
Jan 6, 2014 06:17 AM
caymandrew
May 24, 2013 03:12 PM
Robover01
Nov 27, 2009 11:30 PM
