So I did a thing
Old Jun 3, 2019 | 10:14 PM
FlyingZebra34's Avatar
Default So I did a thing
Well you see it all started when I was replacing the fuel pump. Noticed some rust. Then one thing led to another and now she's stripped down. Going to grind out the rust and re paint it with POR15 then install a ton of dynamat. Also wasted a chunk of change on eBay buying replacement plastic bits. Decided to fix the interior up correctly.
Old Jun 4, 2019 | 03:30 AM
JUKE179r's Avatar
Good luck!
Old Jun 4, 2019 | 08:46 AM
NewToTheTwo's Avatar
Dont use Dynamat unless you just have money to burn.
its just an over priced named brand
Something like this is just as good and cheaper -
Amazon Amazon
Also know that these type products - Dynamat included - are vibration dampening only, not sound deadening - you'll want to layer a sound deadener on top if thats what you're looking for.
Vibration dampening can be sparcely placed while the sound dampening should cover completely.
Old Jun 4, 2019 | 11:06 AM
escott16's Avatar
I used the amazon noico brand and I’m happy with it , the dyno Mat I used on my cobra is way better but on these cars it’s really not worth the extra $$$
Old Jun 4, 2019 | 12:48 PM
CollieRover's Avatar
I’m going to need to do this, excited for your thread.
Old Jun 4, 2019 | 05:02 PM
abran's Avatar
surprised you didn't find a "chunk of change" when taking the interior apart!
Old Jun 4, 2019 | 05:47 PM
To be exact, I found
-Several rounds of 9mm
-Unwrapped condom
-Enough food to feed my dog for a day
-Some legos
-Various wrappers?
-Snap on 10 mm deep socket
-About $5 in change
Old Jun 4, 2019 | 05:53 PM
abran's Avatar
That snapon socket is worth its weight in gold!
Old Jun 7, 2019 | 04:13 PM
XRAD's Avatar
POR15...plastic paint. I did not like it. especially not good for laying on anything except absolutely cleaned bare metal. There are other products like rust mort, followed by a few coats of good paint....
Old Jun 7, 2019 | 04:41 PM
escott16's Avatar
I’ve had good luck with por15 lasted 2-3 years and is just not starting to flake and I didn’t even prep as good as I should have , I’ll be re doing it soon with Eastwood products
