so i swapped the bank 2 O2 sensor,,,
Old Jan 29, 2011 | 02:57 PM
sloppyjoe's Avatar
Default so i swapped the bank 2 O2 sensor,,,
and cleared codes. started up the rig and it will toss a code eventually. reading on the scan tool for bank 2 are really high compared to bank 1.
pulled plugs and inspected for unburnt soot and carbon. nothing. so i believe i may have a lean issue. started looking around and noticed the hose from the stepper to the intake manifold was popped off. plugged it back in and fired up the truck again. same readings.
once i came back up to the house from the garage i thought to myself. "DID I HEAR THE STEPPER MOTOR KICK IN AT ALL?"
will run the rig in a little while around the block and see if anything changes.
any other ideas?
Old Jan 29, 2011 | 03:46 PM
sloppyjoe's Avatar
oh and the truck purrs at 750+- rpm and does not run poorly.
just has crappier then normal gas mileage. when i pulled both O2 sensors both looked almost new on the tips and no oil on the connectors
Old Jan 29, 2011 | 06:05 PM
sloppyjoe's Avatar
Figured it out. Thanks for nothin jerkys
Old Jan 29, 2011 | 06:15 PM
Glad to help asshat.
What was the problem?
Old Jan 29, 2011 | 09:14 PM
jafir's Avatar
And what was it?
Old Jan 29, 2011 | 10:29 PM
lordmorpheus's Avatar
waiting...
robson
Feb 22, 2018 05:42 PM
pdowning6
May 12, 2012 10:30 AM
wediveaxa
Sep 23, 2010 07:12 AM
98roverguy
Sep 28, 2006 09:23 PM
