So where did you drill through your firewall?
x3 on the rubber grommet behind glove box and under the SAI pump! I just pulled a 4 gauge power line thru it.
Also, next to that towards the fender you will see a large oblonged grommet that has a bunch of wires going thru the bottom portion. Top part is wide open and I pulled my 4 gauge ground thru that!
Main wiring harness boot
2x on the main wiring harness boot top left driver side. I pulled my oil pressure gauge wire and driving lamp wire through a new hole I poked with a punch. I put some marine silicone on the outside and dabbed some on the inside. I could not see any light through so I was comfortable with it.
