Solutions to squeaky alternator pulley on '97 Disco?
I tried searching the forum and the Rave CD but didn't come up with anything on this...
I've got a '97 Disco SE7 (4.0 V8) with a squeaky alternator pulley and wanted to see if anyone knew whether it was able to be greased, changed, or if I just needed a new alternator. If it can be changed, does anyone have a part number?
I'll update you when I spin the pulley...
The rough spot you speak of may be obvious or not......if the bearing is REALLY bad you should be able to tell right away.....if it's only a little bad it may not seem too bad to you but will still cause the noise. Bottom line is ....it won't heal itself....If you have local rebuilding shop near you that is usually the best route. A lot of the guys here have had some degree of trouble with the alternators purchased from the major parts stores as far as longevity and reliability....so getting your "land rover" unit rebuilt is more desireable than taking a chance on a Taiwan special.
Capital202
04-03-2014 12:28 AM
collector87
06-04-2010 11:45 AM
Malafax_Dand
04-03-2008 04:24 PM
