Some Maintenance done...
Old Dec 26, 2008 | 09:31 PM
Default RE: Some Maintenance done...
Hey, I went to public school, I do ot even know how to spell solenoid.
Old Dec 26, 2008 | 09:34 PM
sloppyjoe's Avatar
ORIGINAL: Spike555
use firefox it has a auto spell feature )))
Old Dec 26, 2008 | 09:36 PM
tomfraser's Avatar
so is there a solenoid that "kicks the gear out" or is it mechanical?
does this mean new starter or is there anything I can do?
does anyone have the PDF of a guide on the starter I have one of the transfer case and it is just a ****load of diagrams on how it works (not in the rave CD)
Old Dec 26, 2008 | 09:43 PM
sloppyjoe's Avatar
the solenoid is a mechanical deal that is electrically actuated. i believe on our starters you have to replace the starter and solenoid as a unit.
Old Dec 26, 2008 | 09:48 PM
tomfraser's Avatar
ORIGINAL: sloppyjoe
yeah... so the solenoid kicks out the gear, how attached is it to the rest of the starter, is it at all feasible to replace just the solenoid?
I also bet the gear it kicks out took a beating, so is that pretty attached to the motor?
does anyone have any good pictures?
Thanks
BTW: i ask all this as I am 17 with no money for doing repairs the proper way, so almost everything I get is from a junkyard, and the guy at the junkyard will charge 10 bucks for a solenoid and gear, but 100 for a starter
Old Dec 26, 2008 | 09:53 PM
sloppyjoe's Avatar
some vehicles the starter and solenoid are separate and can replaced as such. others are a unit. i believe ours are a 1 piece unit.
the starter gear is attached to the solenoid and will get replaced with a new starter. thats a no brainer BUT if the flywheel gear teeth got munched up then that is a bigger and much more expensive problem as it is attached to the back of the engine and sandwiched between the tranny.
Old Dec 26, 2008 | 09:56 PM
tomfraser's Avatar
yeah... if it's the flywheel, i'm just gonna live with it, but the starter I can replace no problem
Hell... i'll take mine out tommorow and see whats what
Old Dec 26, 2008 | 09:58 PM
sloppyjoe's Avatar
agreed
Old Dec 26, 2008 | 10:05 PM
What sucks is that if you let it go to long you will chew up the teeth on the flywheel, that is a big money repair because you need to pull the engine or drop the tranny.
Take your starter out, tear it apart, if you can fix it for $10 great, if not you'll be buying a used starter.
www.roverlandparts.com, see how much they want.
Old Dec 26, 2008 | 10:08 PM
sloppyjoe's Avatar
ORIGINAL: Spike555
i covered that,,,basically,,,
nice going cleveland
