Some ?'s on the Plenum.
Old Oct 2, 2008 | 12:24 PM
ek5usmc's Avatar
Default Some ?'s on the Plenum.
I know this must get old but knowledge is power and all of it helps!!! I'm going to change my plug wires, and I have the RAVE manual, It has torgue specs as follows:
Plenum Chamber=16flbs
Inlet Manifold Initial=7flbs/Final=38flbs/Gasket clamp bolts=13flbs
My torgue wrench does 20-100flbs, so should I buy a smaller one or just tighten all of them very easy and even? I'm confused on wich bolts are exacly I'll be taken off. I'll be following the instructions from the RAVE, so once I take it all off then I'll know what to torgue. From searching this on here, some torgue and some simply just tighten evenly, whats your thoughts? Thanks everyone!
Old Oct 2, 2008 | 01:13 PM
sailorcolin's Avatar
Default RE: Some ?'s on the Plenum.
just seal it with some water proof silicone and hand tighten them. as long as the silicone seals properly you will not have a leak. But for the bolts just hand tighten them and you will feel when they are tight.
Old Oct 2, 2008 | 06:55 PM
ek5usmc's Avatar
Thanks, all taken care of now.
Alex J
Jan 2, 2010 06:22 PM
sailorcolin
Sep 4, 2008 11:30 AM
sailorcolin
Apr 17, 2008 08:08 PM
tads
Aug 27, 2007 03:22 PM
gtagg
Oct 24, 2006 06:27 PM
