Plenum Problems People!!
Old Aug 25, 2007 | 06:57 PM
tads's Avatar
Default Plenum Problems People!!
I've removed my valve covers to replace the seals. When I removed the plenum chamber, the forward most pipe was lying crooked. I may have knocked it as I removed the chamber. I could remove the pipe completly but I couldn't budge the others.
What's the damage here? I'm new to plenem chambers... what exactly do they do anyway? Thanks.
My truck: 1996 Disco SE7 w/ 140k
Cheers!
Old Aug 26, 2007 | 07:59 AM
Default RE: Plenum Problems People!!
Specifically what pipe are you talking about?
Old Aug 27, 2007 | 09:02 AM
tads's Avatar
I'm talking about the forward most pipe; the one closest the thermostat housing. From inside the truck looking at the engine, it's the forward most pipe on the left.
The pipe was completly out of it's place. Now, as I said before I think I may have bumped it while removing the chamber, but why was it loose to begin with? None of the other pipes even budge.
I tried to put it back into it's seat, but I'm not sure if it's all the way down or not. I'm just curious about how serious a problem this could present...
Cheers!
Old Aug 27, 2007 | 03:22 PM
98roverguy's Avatar
I you did bump it, I didn't know those come apart. I'd take that assemblyy off and inspect it.
Alex J
Jan 2, 2010 06:22 PM
ek5usmc
Oct 2, 2008 06:55 PM
sailorcolin
Sep 4, 2008 11:30 AM
sailorcolin
Apr 17, 2008 08:08 PM
gtagg
Oct 24, 2006 06:27 PM
