Sort of URGENT Engine Info needed CONNECTING ROD HOUSING BORE SIZE
Old Aug 27, 2015 | 04:43 PM
  #41
Charlie_V's Avatar
Originally Posted by antichrist
Here's the conrod bolt info I was referring to:
Turner Engineering ERR 1772 Conrod Bolt - Set 16
As for clearances, the shop could make sure the big end bore is not out of round, install the new shells and rod to the the crank (using the old bolts) and check the final clearance with plastigauge and, if correct, refit the bearing caps using the new bolts.
I ordered those.
HammerFit
Oct 9, 2014 10:26 AM
arod829
Oct 31, 2012 06:59 PM
Bamberson
Oct 26, 2012 09:31 AM
DustyLBottoms
Oct 22, 2012 01:34 PM
Torancis_LR
Jul 10, 2009 11:27 PM
