sounds like a tractor...not good.
I've just completed replacing the timing chain cover gasket on my wifes '02 disco. Followed the RAVE instructions and apart from the odd tricky access problem everything went smoothly...or so I thought. All nuts, bolts and washers were accounted for and labeled so they went back in the same holes. Filled it up with oil and coolant last night and started it up and it sounded like a tractor...almost as if something was hitting something. Turned it off straight away.
I never changed or touched the timing chain and did not fiddle with any moving parts, just removed the oil pan and timing cover, replaced gaskets for both and re-assembled. I can't think what can be the issue...any ideas would be greatly appreciated.
I'll start tearing it apart again this weekend.
