Sponsored by: CARiD
2004 disco sounds like a diesel
Old Oct 6, 2005 | 08:44 AM
Rovercountry's Avatar
4wd High
Default 2004 disco sounds like a diesel
My 2004 disco sounds like a diesel when it's cold and really doesn't get that much quieter after warm-up. It sounds like piston slap to me. Is this a normal, a common problem or something else? Thanx.
Old Oct 6, 2005 | 09:57 AM
Landzu's Avatar
Default RE: 2004 disco sounds like a diesel
Check for a exhaust leak.
Old Oct 7, 2005 | 09:00 PM
rinmud's Avatar
some 2003 and 2004 have a problem with the block and front (oil pump housing)misaligned, it effects oil presure and will eventually send the "driven gear" of the pump through the oil pump housing there is a VIN break call the dealer and have it checked. What you are hearing is a valve tap if this is so.
me 2
May 22, 2013 08:47 AM
evoking
Jan 10, 2012 09:19 PM
RegT
Apr 26, 2010 12:07 PM
jcrosby
Sep 17, 2009 04:20 PM
sandhonwheels
Nov 27, 2008 10:14 AM
