I recently had the catalytic converters stolen from my D2. In the process of removing them, the wretches pulled the plastic connectors off the wire harness. I had a hard time finding replacements while searching for LR connectors, but discovered that Honda and Acura use the same ones. These are available from online vendor Autolumination.com (see links below) for $5-6 each. They come in kits. They are the same quality as the original ones and mate perfectly with the O2 sensor connectors. Their website is rather primitive, but they have lots of useful parts which are well-illustrated, allowing one to do visual match-ups.
uugh... sad to hear that! Im too looking for connectors.. I need the 2 prong power lead that connects to to the blower motor harness on my 2003 discovery SE .. it is the white plug ( male part on the main harness with 12v red and black wire) and 2 spade connectors inside.. suspecting an issue there I bought a good used harness that connects to relays and resistor and bower... it has a few little plugs but the main power plug that connects it to battery power on the disco was burned...
