Spare tire carrier, 6 bolts vs. 4
I just flipped my spare tire carrier to accommodate 265 x 75 x 16 tires.
The middle 2 bolts don't line up. I was going to drill holes for them but noticed those are not just holes drilled for each bolt. There is extra support inside the door for each bolt. So drilling holes may not add any real support.
Any bad experiences with just going with bolts?
Thanks
Thanks
yes, the door design is a six tube frame for tire support. drill the holes and use all the bolts. Six bolts by OEM, and you are putting on a larger heavier tire. If you have a rear wiper arm, it will hit the flipped tire carrier. If you cut the carrier to accommodate the arm, the carrier is now structurally weakened, so you may have to weld some extra metal on to it.
The Deputy (07-14-2020)
