Spare tire carrier, 6 bolts vs. 4
Old Jul 13, 2020 | 12:46 PM
keninnc's Avatar
Default Spare tire carrier, 6 bolts vs. 4
I just flipped my spare tire carrier to accommodate 265 x 75 x 16 tires.
The middle 2 bolts don't line up. I was going to drill holes for them but noticed those are not just holes drilled for each bolt. There is extra support inside the door for each bolt. So drilling holes may not add any real support.
Any bad experiences with just going with bolts?
Thanks
Old Jul 13, 2020 | 01:27 PM
XRAD's Avatar
yes, the door design is a six tube frame for tire support. drill the holes and use all the bolts. Six bolts by OEM, and you are putting on a larger heavier tire. If you have a rear wiper arm, it will hit the flipped tire carrier. If you cut the carrier to accommodate the arm, the carrier is now structurally weakened, so you may have to weld some extra metal on to it.
Old Jul 13, 2020 | 03:01 PM
Alex_M's Avatar
Drill the new holes on the carrier, not the door. Use the steel spacer that is in place from the factory, flipped over, and that will serve as a template for where to place the new holes on the carrier.
Old Jul 13, 2020 | 05:31 PM
Llamasayswhat's Avatar
FWIW, I didn't bother with the center bolts. The load is being carried by the upper and lower bolts.
Old Jul 14, 2020 | 02:40 AM
The Deputy's Avatar
This^^^^
You don't drill the door...the carier needs new holes.
Old Jul 14, 2020 | 07:37 AM
keninnc's Avatar
Thanks everyone.
I was over thinking it when I flipped the spacer bar.
Flip the carrier but not the spacer bar.
Simple pilot hole from the interior of the door through the existing tunnel and then a full size drill bit from the outside to enlarge the new hole in the carrier.
Job done.
pilsner
Aug 13, 2017 04:29 PM
Charlie_V
Jun 14, 2013 09:43 PM
DooDer
Jun 21, 2012 10:30 AM
roarke
Jun 17, 2009 09:48 PM
kclandrover
Nov 26, 2007 11:36 PM
