spark Plug preference
Old Oct 3, 2023 | 07:32 AM
redrover75's Avatar
Put in the Autolite Iridium, seems to run better, smoother. Good news is no oil or steam cleaning in the cylinders. Old ones were not particularly worn/dirty/bad, but I know they are atleast a few years old. Tip for the future, it is probably worth removing the SAI pump to gain better access to the passenger side.
Thanks for the tips.
Old Oct 3, 2023 | 04:20 PM
mln01's Avatar
Which specific Autolite iridium plugs did you install?
Old Oct 5, 2023 | 11:46 AM
redrover75's Avatar
Default Plugs
The ones Chris suggested.
Autolite Iridium. Gap them to .035 - XP3924 4000 Ohm resistance.
They come gapped at .044, just need to regap them.
Now I need to get the O2 sensor out. broke three 1/2" extensions. I need them to get past the exhaust pipe to get the O2 wrench on it. I am thinking about cutting the wire and putting a 22mm box wrench on it. that becomes a point a of now return, mostly runs fine now. Just an occasional stumble. I have been hitting it a couple times a day w penetrant and driving it to heat it up. On the other hand might just be easier to cut out the section and put a new section w the bung in.
Old Oct 6, 2023 | 10:47 AM
Alex_M's Avatar
I wouldn't go through that much trouble if it's running fine. When the time comes, do like you said and cut the wires (or the body of the sensor with a sawzall) and get a socket on there. Wouldn't cut the pipe. Would sooner just drill another hole and weld a new bung in, but if it isn't throwing a code or obviously malfunctioning based on live readings thru a scanner, I wouldn't fool with it.
Old Apr 30, 2026 | 11:13 PM
Doc 5440's Avatar
Originally Posted by mln01
The most important consideration for spark plugs is that they are double-platinum, or double some other precious metal (often iridium).
The reason is that the DII uses a wasted spark ignition system. Google it. Conventional copper plugs wear out quickly if used in a wasted spark system.
Before I started taking care of my truck myself, a local shop installed conventional copper plugs. They lasted just 13,000 miles before the misfires appeared. I replaced them with the OEM Champion 7070s (RC11 PYP B4). They are double-platinum, and were still going strong 72,000 miles later when I replaced them proactively only because I was replacing the wires.
There is a lot of snake oil marketing with spark plugs. On top of that there are heat range specifications to be considered. Other brands that are double-platinum and in the correct heat range may work equally well in your DII, but the 7070s are specified and proven.
what did you gap the champion plugs at?
Old May 1, 2026 | 07:50 AM
mln01's Avatar
They come pre-gapped and should not require adjustment. But I do check the gap. The RAVE Workshop Manual shows the spark plug gap spec as 0.040".
Old May 1, 2026 | 09:39 AM
Externet's Avatar
I believe it is not a brand affair, but about its materials. 100 thousand miles on my OEM quadruple platinum fixed gap unobtanium now. (Bosch 4418 or perhaps 4419)
ShowActive
Oct 23, 2022 02:40 PM
upnatm
Apr 15, 2015 11:36 AM
drowssap
Mar 18, 2011 08:26 PM
cpn LR
Nov 20, 2010 10:02 PM
adwarren78
Mar 24, 2009 07:52 PM
