Had a Spark Plug Thread break off
Old Mar 22, 2009 | 10:57 PM
adwarren78's Avatar
Default Had a Spark Plug Thread break off
Cylinder 1 spark plug was tight when removing. Thought it might have been stuck or cross threaded. Used some PP Blaster on it and finally got it loose enough to come out. Noticed one of the threads had broken off and is stuck on the plug. The new plug went in but was a little tight. Has any body else seen this and do you think it could be a problem. I put never sieze on the new plugs when I installed them.
Old Mar 22, 2009 | 11:25 PM
tornado_735's Avatar
I wouldn't see it as being a problem, as long as none of the metal got into the hole, and as long as it doesn't lose compression. But I might be wrong...
Old Mar 23, 2009 | 10:48 AM
I would suggest pulling that plug again and putting some spark plug lube on it as well as your other ones so this doesn't happen to the rest.
Old Mar 23, 2009 | 10:27 PM
roverguy7's Avatar
if you used anti sieze youll be ok, as long as it sealed. and you might want to replace the plugs on the early side next time you do, dont let them start to get stuck, or youll be in a world of trouble with the one thats already on its way out.
Old Mar 23, 2009 | 11:04 PM
lol you might want to put a little 'extra' anti-seize on that plug!
Old Mar 24, 2009 | 07:48 PM
adwarren78's Avatar
Yes, I did put antiseize on the plugs before I reinstalled them. The cylinder with the problem screwed back in fine luckly the rest of the threads were ok
Old Mar 24, 2009 | 07:52 PM
adwarren78's Avatar
Hey tornado_735 just noticed your from Columbus, I went to OSU and am now living on Indian Lake, nice to see some local people on here
univu2
Jul 28, 2012 08:03 PM
primey
Oct 26, 2011 07:24 PM
xb70valkarye
Mar 15, 2009 06:46 PM
George Dow
May 1, 2008 11:44 AM
