Spark Plug removal question
OK here is how to get plugs out that were in forever..
Once you hit resistance - you GO back in for 1/2 turn or 180 degrees.
Then back out until resistance
then back in.
Eventually you'll get the plugs out this way.
If you man handle them out without backing them in and out.
You may ruin the threads in the head.
then back in.
I was also mildly shocked to find that the plugs look surprisingly normal - at first I thought the electrode wear was a bit excessive, but looking at pics on the 'net, it appears that the PYPB4 has a tapered electrode to begin with.
I did discover that the driver's side is a LOT easier once you pop off the intake tube between the MAF and the throttle body...even then I still did a pretty good number on my knuckles.
I definitely need to do the wires, gonna order some 8mm this week - the factory ones are a little on the rough side. I anticipate that being a battle, as well...
Thanks for the help guys!
