Speaker fiber optics plug?
Old Aug 4, 2023 | 10:02 AM
norseman73's Avatar
Default Speaker fiber optics plug?
I am in need of this plug. My speakers on the driver side of my HSE are not working and I believe this may be the culprit? Does anyone know where I can purchase one of these plugs?
This plug is busted and I believe it is causing my speakers on the driver side of my HSE to not work? Any help would be most appreciated. Especially if you have one for sale.
Old Aug 4, 2023 | 10:28 AM
Externet's Avatar
Diagnose, diagnose first. Disconnect from the radio amplifier the non-working speaker cables, they may be under driver's seat. Connect instead a known good speaker.
Same fault = is a radio/amplifier fault.
Where was that plug at ? Never seen such.
Old Aug 4, 2023 | 02:32 PM
norseman73's Avatar
It was in the rear driver side door. I closed the door on it and broke it when I was replacing the actuator to the window.
Old Aug 5, 2023 | 08:27 AM
The_OGCJR's Avatar
I doubt that the fiber optics plug is the culprit. Mainly because, in most cases the fiber optics wire would plug into the amp and stop there.
You would be looking for speaker wire from the amp to the speaker. Those are not fiber optic
Old Aug 5, 2023 | 11:28 AM
norseman73's Avatar
Thank you I'm tracing down those wires now.
Old Aug 7, 2023 | 07:40 AM
cmansilla's Avatar
This is not a FO connector, this is a windows switch without the cap, if you remove the cap you can see the green led that illuminates the switch
Ratledge
Jul 16, 2023 08:11 PM
jlazyr@gmail.com
LR4
Jun 28, 2021 04:14 PM
Big Jim Swade
Jun 1, 2021 01:15 PM
2k3evoviii
Range Rover L322 (3rd Gen)
Jan 31, 2020 10:40 AM
DAMINK
Aug 18, 2015 04:09 PM
