Speaking of trans fluid..
I know there are a million posts about the motor flush with straight trans fluid, but im a little leary of it.Ive done a seafoam flush and always ran RP sythetic, but as ive read if there happens to be junk in the valve train, which may or may not be associated with this engine noise i have, the trans fluid flush really works. Someone convince to give it a try.
on
Dealers and shops started using ATF, diesel fuel and or kerosene more then 20 years ago and many still do. Most now stay away from the kerosene and diesel fuel because of saftey/smell issues.
ATF works great if you want to do a more rapid engine flush and don't want to pay $100 plus at the shop for a similar flush.
thats what i was thinking. does thetrans fluid really help with noisy lifters. in o ther words im not sure whats going on in my motor but if it was bottem end related, these last 20k would have made it more evident, but i know these motors have crummy lifters from the get go and if a flush helps even for a few minutes i could narrow down the noise. its still hard to fathom lifters in a motor going bad with only synthetic,knocking at 88k. But even lifters bottoming out will cause wear on the cam, and steel in the oil analysis which didnt show up on my last test.....
The People Family
08-06-2008 10:32 PM
